Windshield wiper question, hope this isn't too dumb of a question |
David_S |
Aug 13 2003, 11:43 PM
Member Group: Members Posts: 430 Joined: 11-May 03 From: Dimmitt, Tx Member No.: 680 Region Association: Southwest Region |
I was messing with my wipers today and can't get them to work on high, figured out I need a new switch in the column. I also noticed that Hayne's says this is a two speed motor, so I would think that the switch would have three positions(off, low, and high), but my switch has four positions. What is the fourth position for? Car is a 1973. What am I overlooking ??? Thanks .....David
SirAndy |
Aug 14 2003, 12:59 AM
Resident German Group: Admin Posts: 41,682 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(David_S @ Aug 13 2003, 10:43 PM) I was messing with my wipers today and can't get them to work on high, figured out I need a new switch in the column. I also noticed that Hayne's says this is a two speed motor, so I would think that the switch would have three positions(off, low, and high), but my switch has four positions. What is the fourth position for? Car is a 1973. What am I overlooking ??? Thanks .....David if position 4 is down, then it's for the intermittent they never hooked up. some cars have it on the column, but it was never used. you can, however, add a sort of intermittent by adding a intermittent relay to your wire harness. the factory has already a place reserved for that. however, that intermittent relay only works in conjunction with your windshield washer, meaning your wipers will run 3 or 4 times when you activate the windshield washer ... a article on how to hook this up can be found here: Wiper relay instructions ... later, Andy |
Lo-Fi Version | Time is now: 12th June 2024 - 05:17 AM |
