> Taking a plasma cutter to my dash board, how the hell do you pry this thing off?
VaccaRabite
post Oct 18 2005, 07:07 PM
En Garde!
Okay, after work I thought I would get the dash off, get most of the wire harness pulled back to at least the engine firewall, and get all the junk out of the front trunk.
Well, none of those three things got done. The front trunk still has lights, some wires, and brake fluid lines - everything else is out. The brake lines I just got lazy and did not want to deal with draining.
The wire harness, well its still attached to the headlights, so its not going anywhere.
And the dashboard. That mother fsking dashboard....
How do you get the SOB out of there? I have the 4 bolts undone from the front trunk. I have the side bolts out by the air vents. All the instuments, vents, wires, and knobs are out. The vynal trim is off the dash face. The steering wheel is hanging on my wall. The only things left in the dash are the glove box and the mount for the ashtray.
I can get the dash to move around, but I can't get it out of the car. Do I need to remove the seal around the inside of the widshield? I realized that I was getting too frusterated to be useful, so I closed up my haynes manual and came inside to querry the 914 hive mind.
Thanks all,
Zach
VaccaRabite
post Oct 18 2005, 07:57 PM
En Garde!
QUOTE (flesburg @ Oct 18 2005, 08:32 PM)
Are you going to reinstall it or are you building a race car? I took one out of our track car last year and already had a roll cage in the car. I had to cut it in pieces to get it out. I was able to get the padded top out in one piece, but had to cut up the sheetmetal "dash board".
Eek. I don't want to cut up the dashboard. Or have to break the windshield out. The windshield is in pretty good shape. If I need to replace the seals around it, I'll take it out to do that, but other wise, I'd like to leave well enough alone.
Tomorrow, I'll look for those plastic nuts. I saw the ones behind the steering wheel. The haynes manual never mentioned anyhting about the plastic nuts. Of course, I am finding out that there are a lot of things that the haynes manual odes not mention. (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif)
Okay, I am going to try and clear the dirt out from undermy fingernails and head off to bed. I have to be at work way to early tomorrow.
Zach
- Lo-Fi Version Time is now: 17th July 2025 - 03:06 AM
