boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
I am trying to take my *new* 1970 914 1.7L to get inspected so I can transfer the title in AZ (out of state car transferring title to AZ).
Anyone know if I can transfer the title and have it titled as a car under "restore" in AZ? She doesn't want to "go" from a stand still. Engine will die if you don't keep the gas pedal down and let up *very* easy on the clutch. If it feels like it is going to stall, just press clutch back in and she keeps running. I assume this is "needs a new clutch". Correct? Planning on tearing this car down, dip, paint and put in a 3.2L. If I replace clutch now, can I purchase a 5-spring clutch that will work with the later 3.2L? boxsterfan |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Sounds like the problem I was having when I was leaking oil on my clutch. You might wanna change the rear oil seal and check the crank endplay while you're in there (famous last words).
Lo-Fi Version | Time is now: 15th July 2025 - 03:16 AM |
