how to drain a tranny?, how do i do it? |
shaggy |
Oct 30 2005, 08:16 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
my tranny is leaking from that plate in the rear that is held on with 4 10mm nuts
its not leaking really bad but every day there is some oil i know its coming from there cuz i look down there and i can see that there are drops of oil forming opn those screws i have tightened those nuts and found no result is it possible that my seal is bad? if so could i just drain my tranny take that plate off clean both surfaces put a new seal in and but it back together? then re fill it? how exactly do i drain and refill a tranny properly? what is the size of that massive hex wrench? |
ejm |
Oct 30 2005, 08:38 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
be sure you can remove the fill plug before you drain it....you can make your own tool with a bolt and a couple of nuts.....
the plate has a gasket p/n 914 301 391 00 and tell your folks I said Hi (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:39 PM |
