| michelko |
Nov 1 2005, 10:53 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
Hi everybody,
have a mysterious suspension problem. Sometimes on a bumpy road the car is shaking a bit side to side. Changed the tie rods to turbo style, mounted bump steer kit, adjusted the toe in to factory spec, every screw connection is fastened. what else can i do (check)? Any body know this problem or the remedy? I am sure it is not the bump steer problem!!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
Aaron Cox was it aligned afterword?
is your car lowered? th... Nov 1 2005, 10:58 AM
Joe Ricard Define shaky. like going over bump in curve and t... Nov 1 2005, 11:04 AM
michelko it feels like the whole front of the car is moving... Nov 1 2005, 11:15 AM
lagunero lug nuts tight? new tires grabbing grooves of road... Nov 1 2005, 11:18 AM
SLITS Rain grooves in driving surface?
Shitty roads
Po... Nov 1 2005, 11:19 AM
michelko tires are new.
wheel bearings not checked till no... Nov 1 2005, 11:39 AM
michelko a forgot: anti roll bar in, no difference!
Nov 1 2005, 11:41 AM
goose2 shocks? Nov 1 2005, 12:30 PM
Headrage Bent wheel? Nov 1 2005, 12:31 PM
SLITS <... Nov 1 2005, 12:54 PM
Joe Ricard Yea, I agree now it sounds like you need to go in... Nov 1 2005, 01:06 PM
Thorshammer How wide are the front wheels and where is the cas... Nov 1 2005, 01:32 PM
r_towle I chased a shimmy for quite a while...
I changed ... Nov 1 2005, 04:55 PM
michelko Nov 1 2005, 11:33 PM
michelko After some inspection of the suspension parts, cha... Nov 13 2005, 01:58 PM
r_towle vertical wheel shake on the front tires is the bal... Nov 13 2005, 05:41 PM
Spoke Had the wandering thing also. Tie rod ends were sh... Nov 13 2005, 10:31 PM
michelko Nov 14 2005, 12:30 PM
Eric_Shea Hey Rich... Check this out!
I agree with Rich... Nov 14 2005, 12:39 PM
michelko purchased already a set of new wheel bearings. Thi... Nov 16 2005, 11:29 AM
Brotherbob I would mount the rear tires on the front and fron... Nov 16 2005, 11:36 AM
michelko ... Nov 28 2005, 08:09 AM
michelko Nov 28 2005, 08:32 AM
Aaron Cox where do you get your parts? do you go down to mit... Nov 28 2005, 10:44 AM
michelko Mar 24 2006, 08:35 AM
rhodyguy brad told me to cut the bump stop in half. liberal... Mar 24 2006, 10:31 AM
Dr Evil I use a pipe wrench and then put gobs of anti siez... Mar 24 2006, 10:38 AM
DEC Michael,
call me http://www.... Mar 24 2006, 10:51 AM
SirAndy ... Mar 24 2006, 11:43 AM
michelko <... Mar 25 2006, 12:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 04:25 AM |
