| michelko |
Nov 1 2005, 10:53 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
Hi everybody,
have a mysterious suspension problem. Sometimes on a bumpy road the car is shaking a bit side to side. Changed the tie rods to turbo style, mounted bump steer kit, adjusted the toe in to factory spec, every screw connection is fastened. what else can i do (check)? Any body know this problem or the remedy? I am sure it is not the bump steer problem!!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
| r_towle |
Nov 1 2005, 04:55 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I chased a shimmy for quite a while...
I changed everything... I found two things. First was the bottom of the strut tube where the ball joint is installed, the round hole that the ball joint slides into was out of round...this created a wobble . The second was simple, but annoying. The rear of the torsion bars has a felt washer over it. It ensures that the torsion bar stays centered. Well, after 30 years, the felt is gone...I replaced it with a rubber washer. This stopped the clunk. Rich |
michelko shaky suspension ? Nov 1 2005, 10:53 AM
Aaron Cox was it aligned afterword?
is your car lowered? th... Nov 1 2005, 10:58 AM
Joe Ricard Define shaky. like going over bump in curve and t... Nov 1 2005, 11:04 AM
michelko it feels like the whole front of the car is moving... Nov 1 2005, 11:15 AM
lagunero lug nuts tight? new tires grabbing grooves of road... Nov 1 2005, 11:18 AM
SLITS Rain grooves in driving surface?
Shitty roads
Po... Nov 1 2005, 11:19 AM
michelko tires are new.
wheel bearings not checked till no... Nov 1 2005, 11:39 AM
michelko a forgot: anti roll bar in, no difference!
Nov 1 2005, 11:41 AM
goose2 shocks? Nov 1 2005, 12:30 PM
Headrage Bent wheel? Nov 1 2005, 12:31 PM
SLITS <... Nov 1 2005, 12:54 PM
Joe Ricard Yea, I agree now it sounds like you need to go in... Nov 1 2005, 01:06 PM
Thorshammer How wide are the front wheels and where is the cas... Nov 1 2005, 01:32 PM
michelko Nov 1 2005, 11:33 PM
michelko After some inspection of the suspension parts, cha... Nov 13 2005, 01:58 PM
r_towle vertical wheel shake on the front tires is the bal... Nov 13 2005, 05:41 PM
Spoke Had the wandering thing also. Tie rod ends were sh... Nov 13 2005, 10:31 PM
michelko Nov 14 2005, 12:30 PM
Eric_Shea Hey Rich... Check this out!
I agree with Rich... Nov 14 2005, 12:39 PM
michelko purchased already a set of new wheel bearings. Thi... Nov 16 2005, 11:29 AM
Brotherbob I would mount the rear tires on the front and fron... Nov 16 2005, 11:36 AM
michelko ... Nov 28 2005, 08:09 AM
michelko Nov 28 2005, 08:32 AM
Aaron Cox where do you get your parts? do you go down to mit... Nov 28 2005, 10:44 AM
michelko Mar 24 2006, 08:35 AM
rhodyguy brad told me to cut the bump stop in half. liberal... Mar 24 2006, 10:31 AM
Dr Evil I use a pipe wrench and then put gobs of anti siez... Mar 24 2006, 10:38 AM
DEC Michael,
call me http://www.... Mar 24 2006, 10:51 AM
SirAndy ... Mar 24 2006, 11:43 AM
michelko <... Mar 25 2006, 12:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 04:24 AM |
