I'm depressed, 2 hours of dyno time for nut'n....., Ignition cr@pped out, wouldn't restart:( |
Mueller |
Nov 1 2005, 06:12 PM
What a waste of a day off.... (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
I knew it was going to be one of those days when my laptop wouldn't communicate with the Link ECU, luckly I brought a back up unit that I normally use, it's just that the 1st laptop I had was way, way faster...(normally) Mark D (McMark) showed up and helped stomp on the gas while I played with the laptop, we started @ 1000rpm and went up in 500rpm increments...strange feeling with the pedal @ WOT in 4th gear and the motor would not go over the set load... I kept hearing a misfire and then all of a sudden under load it got real bad, we changed out the distributor cap since the original one had some viewing holes cut into it for timing....it just got worse...then I noticed the air intake elbow was a little loose so I fixed that...I was hopeing that was it...nope still really bad misfires coming out of the exhaust....finally I load a new MAP setting and the car seemed to be idling better, then all of a sudden the car dies..."hey Mark, did you turn it off???" "nope" "oh $hit" I get out the voltmeter, I have voltage like I should, no apperant spark.... So, it's one of the following I think (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) a bad MSD box, a bad optical sensor in the dizzy or the Link is messed up....I have a check list of items to go over before sending the Link back for testing.... I think i want to replace the optical sensor within the dizzy with a hall effect unit, any leads or ideas? McMark dyno's his car, I'll let him tell you about it...he had better luck than me |
Mueller |
Nov 1 2005, 07:50 PM
we have a "runner"......problem fixed...sorta...
broken electrode on the rotor...... The original electrode was too skinny and giving me problems with spark scatter, so I rigged up a new one. It had no issues with the original distributor cap... Once we installed the new cap, the car really ran terrible until it just wouldn't run any more....I "think" this could be the reason (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) No new rotor, I fixed the broken one to at least get the car off the trailer and into the garage....I still have a slight miss that I have to hunt down. James, I think I will switch it back to running only the fuel with the Link and tune it that way for now. Attached image(s) |
Lo-Fi Version | Time is now: 17th June 2024 - 09:58 AM |
