6/carbs: ? about tall 2ndary venturi's, rich, I miss you. |
brant |
Nov 3 2005, 11:50 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Hi all... thanks for the help in advance. I want to try a set of the tall 2ndary's on my IDS-3C carbs. I'm running the stock ones and want to try the tall ones, that I've heard called "906-style" its a race car and withoug re-hashing all of my jetting and dyno history, my questions are: 1) pierce manifold says they have 2 different types in stock a 3.5 size and a 4.5 size. I believe this measurement is in reference to bore and not height. Pierce said that both sizes are the "tall" type. Which do I want? Motor is a 1967 2.0/S motor at altitude. (the pierce catalogue references that the IDS carbs came with 4.5 short, but I'd like confirmation before I order) 2) Does anyone know if these tall secondaries interchange on the IDA carb versus the IDS carb. I would assume so, but I once bought some F33 emulsion tubes from Pierce that do fit the IDA, and found that they would not fit the IDS. I didn't know there was that much difference between the two carbs, which surprised me. But again, before I order do people know if the 906-type tall 2ndaries will fit an IDS-3C body? again, thanks in advance everyone! brant |
J P Stein |
Nov 3 2005, 06:21 PM
I've heard a few things about "why"....internet stuff, mostly.
Lotta salt grains here. My carbs came to me with em' and I didn't have to "fix" anything. whut I hear: Better mid range. Less fuel reversion in the aux venturi (the gas comes in there) with long duration cams due to the increased height. Used first on the 906 (with 906 cams...go figure) Thas all I might know. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Steve Wiener could give you the straight scoop |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:56 AM |
