Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
What a waste of a day off.... (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
I knew it was going to be one of those days when my laptop wouldn't communicate with the Link ECU, luckly I brought a back up unit that I normally use, it's just that the 1st laptop I had was way, way faster...(normally) Mark D (McMark) showed up and helped stomp on the gas while I played with the laptop, we started @ 1000rpm and went up in 500rpm increments...strange feeling with the pedal @ WOT in 4th gear and the motor would not go over the set load... I kept hearing a misfire and then all of a sudden under load it got real bad, we changed out the distributor cap since the original one had some viewing holes cut into it for timing....it just got worse...then I noticed the air intake elbow was a little loose so I fixed that...I was hopeing that was it...nope still really bad misfires coming out of the exhaust....finally I load a new MAP setting and the car seemed to be idling better, then all of a sudden the car dies..."hey Mark, did you turn it off???" "nope" "oh $hit" I get out the voltmeter, I have voltage like I should, no apperant spark.... So, it's one of the following I think (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) a bad MSD box, a bad optical sensor in the dizzy or the Link is messed up....I have a check list of items to go over before sending the Link back for testing.... I think i want to replace the optical sensor within the dizzy with a hall effect unit, any leads or ideas? McMark dyno's his car, I'll let him tell you about it...he had better luck than me |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
rock on james....
so, an adjustable one set at max advance, ABOVE 3k, would not work? |
Lo-Fi Version | Time is now: 17th June 2024 - 12:05 PM |
