Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,098 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Dammit! It runs great on 2 cylinders!!! Except for the occasional backfire. 1 and 3 fire, 2 and 4 do not.
I dunno. I pulled all of the injectors and fuel lines in the engine bay. They're all clear. I have 29 pounds of fuel pressure. I tested all of the injectors while cranking the engine over. All squirt fuel in a nice conical pattern and the volume appears to be the same. I have spark on all cylinders. But only 1 and 3 fire. If I pull the injector connector or the plug wire off of cylinders 2 or 4, nothing changes. They are both not doing anything. If I pull either the injector connector or the plug wire from cylinders 1 or 3, the engine dies; apparently it can't run on just one cylinder, go figure. I'm wide open to suggestions. I need a 914 fix before the weather turns to crap. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Update! If you read all of this thread, you'll see that bondo spotted my error. I swapped wires on the dizzy for cylinders 2 and 4 and she fired right up on all four cylinders. |
Gint |
Pulled the wires at the plug end and checked them for spark against ground. And ofcourse with me as the ground (I hate doing that). (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 1st August 2025 - 10:14 AM |
