Stock sway bar shifting side to side |
Marlow |
Nov 4 2005, 08:51 PM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
What keeps the front sway bar centered? My sway bar seems to shift towards the passenger side of the car every time I've checked it. The drop link rubs against the strut housing. There doesn't appear to be anything missing that I can see. I've had to re-center it several times over the years -- I just wack it with a 5lb mallet and a block of wood until it's centered but it's annoying me now. Any ideas?
davep |
Nov 4 2005, 09:01 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
There is nothing to really keep it centered. However, I think it would only walk if the forces on it are not even. Check the rubber bushings are in good shape. If the bar is stock, then the ends are square and should not try to go through the bushing. The lever arms may not be centered on the ends. Or something may be bent, putting an axial force on the bar in addition to the torque.
Lo-Fi Version | Time is now: 9th June 2024 - 11:52 AM |
