> 6/carbs: ? about tall 2ndary venturi's, rich, I miss you.
brant
post Nov 3 2005, 11:50 AM
Hi all... thanks for the help in advance.
I want to try a set of the tall 2ndary's on my IDS-3C carbs.
I'm running the stock ones and want to try the tall ones, that I've heard called "906-style"
its a race car and withoug re-hashing all of my jetting and dyno history, my questions are:
1) pierce manifold says they have 2 different types in stock a 3.5 size and a 4.5 size. I believe this measurement is in reference to bore and not height. Pierce said that both sizes are the "tall" type. Which do I want? Motor is a 1967 2.0/S motor at altitude.
(the pierce catalogue references that the IDS carbs came with 4.5 short, but I'd like confirmation before I order)
2) Does anyone know if these tall secondaries interchange on the IDA carb versus the IDS carb. I would assume so, but I once bought some F33 emulsion tubes from Pierce that do fit the IDA, and found that they would not fit the IDS. I didn't know there was that much difference between the two carbs, which surprised me. But again, before I order do people know if the 906-type tall 2ndaries will fit an IDS-3C body?
again, thanks in advance everyone!
brant
TimT
post Nov 4 2005, 10:12 PM
retired
When you get (as I see it) the standing waves of fuel bouncing around in an air cleaner (not enuff room overhead), it raises hell with the working intake system harmonics. Note: there is a lot of conjecture here.
hehe Werd (IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
its not really conjecture though. One of the great things about fuel injection, EFI, and sequential injection specifically is that you can adjust the injector end angle such that no fuel is being released when you have reversion (exhaust closed piston moving up intake open). Ya get better efficiency, less emmisions because fuel isnt getting into the engines cycle except when it is needed.
Carbs cant do this..every time the piston descends it draws vacuum and hence fuel from the carb..this charge of fuel hangs in the manifold and gets bounced around until it is finally used
brant   6/carbs: ? about tall 2ndary venturi's   Nov 3 2005, 11:50 AM
Root_Werks   Actually, Jake Raby had a decent write up on stack...   Nov 3 2005, 12:01 PM
brant   Dan, I think your referencing the horns I...   Nov 3 2005, 12:06 PM
Jake Raby   All my testing would not apply to the six... It ha...   Nov 3 2005, 12:06 PM
Root_Werks     Nov 3 2005, 12:59 PM
Aaron Cox   doesnt JP have tall ones on hez carbZ? Just a lea...   Nov 3 2005, 01:06 PM
Howard R   I got mine from PMO.   Nov 3 2005, 01:10 PM
brant   Howard, JP, do you guys know if yours are 3.5 or...   Nov 3 2005, 01:40 PM
Phoenix-MN   I have the tall ones on my 2.5L 911, I'll look...   Nov 3 2005, 02:00 PM
john rogers   My race engine has the real tall ones and the card...   Nov 3 2005, 02:37 PM
brant   Thanks Paul! John... is the 3.5 versus 4.5 a...   Nov 3 2005, 04:27 PM
john rogers   Yes, larger bore.   Nov 3 2005, 05:14 PM
brant   cool thanks John! (I didn't even know the...   Nov 3 2005, 05:46 PM
J P Stein   Oh boy, I get to post my only artsy pic....that I ...   Nov 3 2005, 06:01 PM
trekkor   that picture makes me happy http...   Nov 3 2005, 06:12 PM
Aaron Cox   gawd - what did those milled aircleaner bases set ...   Nov 3 2005, 06:14 PM
J P Stein   I've heard a few things about "why"....interne...   Nov 3 2005, 06:21 PM
J P Stein   ...   Nov 3 2005, 06:24 PM
Aaron Cox   whatchu runnin now JP? ITG style? wonder if th...   Nov 3 2005, 06:27 PM
brant   Its the reversion issue and my 4K stumble that has...   Nov 3 2005, 06:37 PM
J P Stein     Nov 3 2005, 06:49 PM
Aaron Cox   what is reversion? im a newb ...   Nov 3 2005, 07:04 PM
J P Stein   The only place I've actually seen this was on ...   Nov 3 2005, 07:07 PM
brant   I should add that I'm not sure I actually have...   Nov 3 2005, 07:15 PM
campbellcj   I have the tall secondaries on my car but also was...   Nov 4 2005, 12:24 AM
J P Stein   I run my engine quite rich on the idles....so rich...   Nov 4 2005, 12:30 AM
MecGen   Hi Aaron   Nov 4 2005, 02:40 PM
Thorshammer   http://www.914world.com/bbs2...   Nov 4 2005, 09:35 PM
TimT
  Nov 4 2005, 10:12 PM Phoenix-MN   Back to the original question - I'm running th...   Nov 5 2005, 08:25 AM
Thorshammer   Tim is right. Late injected fuel injection has th...   Nov 5 2005, 08:58 AM
Phoenix-MN   Also found this - "Other performance-enhancing op...   Nov 5 2005, 09:24 AM
- Lo-Fi Version Time is now: 4th July 2025 - 12:57 AM
