6/carbs: ? about tall 2ndary venturi's, rich, I miss you. |
brant |
Nov 3 2005, 11:50 AM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Hi all... thanks for the help in advance. I want to try a set of the tall 2ndary's on my IDS-3C carbs. I'm running the stock ones and want to try the tall ones, that I've heard called "906-style" its a race car and withoug re-hashing all of my jetting and dyno history, my questions are: 1) pierce manifold says they have 2 different types in stock a 3.5 size and a 4.5 size. I believe this measurement is in reference to bore and not height. Pierce said that both sizes are the "tall" type. Which do I want? Motor is a 1967 2.0/S motor at altitude. (the pierce catalogue references that the IDS carbs came with 4.5 short, but I'd like confirmation before I order) 2) Does anyone know if these tall secondaries interchange on the IDA carb versus the IDS carb. I would assume so, but I once bought some F33 emulsion tubes from Pierce that do fit the IDA, and found that they would not fit the IDS. I didn't know there was that much difference between the two carbs, which surprised me. But again, before I order do people know if the 906-type tall 2ndaries will fit an IDS-3C body? again, thanks in advance everyone! brant |
TimT |
Nov 4 2005, 10:12 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
hehe Werd (IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) its not really conjecture though. One of the great things about fuel injection, EFI, and sequential injection specifically is that you can adjust the injector end angle such that no fuel is being released when you have reversion (exhaust closed piston moving up intake open). Ya get better efficiency, less emmisions because fuel isnt getting into the engines cycle except when it is needed. Carbs cant do this..every time the piston descends it draws vacuum and hence fuel from the carb..this charge of fuel hangs in the manifold and gets bounced around until it is finally used |
Lo-Fi Version | Time is now: 10th June 2024 - 10:45 AM |
