> My 2.0 runs on 2 cylinders (1 and 3 only), Help a brother out!
Gint
post Nov 4 2005, 05:43 PM
Mike Ginter
Dammit! It runs great on 2 cylinders!!! Except for the occasional backfire. 1 and 3 fire, 2 and 4 do not.
I dunno. I pulled all of the injectors and fuel lines in the engine bay. They're all clear. I have 29 pounds of fuel pressure. I tested all of the injectors while cranking the engine over. All squirt fuel in a nice conical pattern and the volume appears to be the same. I have spark on all cylinders. But only 1 and 3 fire. If I pull the injector connector or the plug wire off of cylinders 2 or 4, nothing changes. They are both not doing anything. If I pull either the injector connector or the plug wire from cylinders 1 or 3, the engine dies; apparently it can't run on just one cylinder, go figure.
I'm wide open to suggestions. I need a 914 fix before the weather turns to crap.
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
Update!
If you read all of this thread, you'll see that bondo spotted my error. I swapped wires on the dizzy for cylinders 2 and 4 and she fired right up on all four cylinders.
Gint
post Nov 4 2005, 11:32 PM
Mike Ginter
...and the muffler bearing. While I'm in there...
Gint   My 2.0 runs on 2 cylinders (1 and 3 only)   Nov 4 2005, 05:43 PM
bmunday   Ok I got the fix... Get a pen and paper, write thi...   Nov 4 2005, 05:47 PM
SLITS   Gint...valves on 2 & 4 too tight (1st guess).... t...   Nov 4 2005, 06:04 PM
Gint     Nov 4 2005, 06:17 PM
onrails   f.i. trigger points? they fire two at a time. ...   Nov 4 2005, 06:21 PM
Brian_Boss   I would pull the spark plugs on the non firing cyl...   Nov 4 2005, 06:22 PM
bondo   Is there any chance the plug wires got swapped bet...   Nov 4 2005, 06:27 PM
Gint     Nov 4 2005, 06:29 PM
Gint     Nov 4 2005, 06:38 PM
bondo     Nov 4 2005, 06:56 PM
Aaron Cox     Nov 4 2005, 07:03 PM
vsg914   If you aren't dislexic(sp) about the 1432 ccw ...   Nov 4 2005, 07:43 PM
SLITS     Nov 4 2005, 08:20 PM
SGB   yep. I done that too, htt...   Nov 4 2005, 08:32 PM
Aaron Cox     Nov 4 2005, 08:34 PM
boxstr   Mike Doe's this car have the injector resistor...   Nov 4 2005, 11:20 PM
Gint     Nov 4 2005, 11:28 PM
Aaron Cox   too funny mike.... stupid shit that makes these c...   Nov 4 2005, 11:30 PM
Gint   ...and the muffler bearing. While I'm in ther...   Nov 4 2005, 11:32 PM
bd1308   upgrade to the O-Pipe and get the engine oil bypas...   Nov 4 2005, 11:52 PM
dlo914   slight hi-jack...would a 311 905 205 AE distributo...   Nov 5 2005, 02:12 AM
bd1308   type 3 was D-jet...it was a 1.6L though. might hav...   Nov 5 2005, 06:17 AM
Gint   I might be interested in it Britt. Can you tell m...   Nov 5 2005, 10:10 AM
bd1308   i have 2 1: the distributor that came with my car...   Nov 5 2005, 10:39 AM
Gint   OK, let me ask again, can you get me th epart numb...   Nov 5 2005, 10:42 AM
bd1308   I cleaned it out. I'll PM you part numbers soo...   Nov 5 2005, 10:44 AM
Gint   No that the rain has stopped I went out and swappe...   Nov 5 2005, 11:39 AM
bd1308   no dizzy needed then? b   Nov 5 2005, 11:49 AM
Gint     Nov 5 2005, 01:36 PM
bd1308   i'll get the part numbers..... and pics. b   Nov 5 2005, 01:47 PM
bd1308   on the original: 039 905 205A (B ) 0 231 174 011 ...   Nov 5 2005, 01:57 PM
Gint     Nov 5 2005, 03:02 PM
bd1308   the B part is the one with the Bosch symbol next t...   Nov 5 2005, 03:07 PM
Gint     Nov 5 2005, 06:20 PM
bd1308   http://reactornet.net/gallery/view_album.p...bumNa...   Nov 5 2005, 07:28 PM
SLITS   0 231 169 011 (also intechanges to 0 231 184 004) ...   Nov 8 2005, 11:25 AM
bd1308   ron..... no. the rebuilders used a core case, w...   Nov 8 2005, 12:49 PM
Triaddave   i had the same problem a few years ago. i would lo...   Nov 8 2005, 01:00 PM
Gint     Nov 8 2005, 05:34 PM
Gint   ...   Nov 8 2005, 05:36 PM
Joe Sharp   http://www.914world.com/bbs2/html/e...   Nov 8 2005, 09:39 PM
- Lo-Fi Version Time is now: 1st August 2025 - 10:11 AM
