> My 2.0 runs on 2 cylinders (1 and 3 only), Help a brother out!
Gint
post Nov 4 2005, 05:43 PM
Mike Ginter
Dammit! It runs great on 2 cylinders!!! Except for the occasional backfire. 1 and 3 fire, 2 and 4 do not.
I dunno. I pulled all of the injectors and fuel lines in the engine bay. They're all clear. I have 29 pounds of fuel pressure. I tested all of the injectors while cranking the engine over. All squirt fuel in a nice conical pattern and the volume appears to be the same. I have spark on all cylinders. But only 1 and 3 fire. If I pull the injector connector or the plug wire off of cylinders 2 or 4, nothing changes. They are both not doing anything. If I pull either the injector connector or the plug wire from cylinders 1 or 3, the engine dies; apparently it can't run on just one cylinder, go figure.
I'm wide open to suggestions. I need a 914 fix before the weather turns to crap.
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
Update!
If you read all of this thread, you'll see that bondo spotted my error. I swapped wires on the dizzy for cylinders 2 and 4 and she fired right up on all four cylinders.
bd1308
post Nov 5 2005, 06:17 AM
Sir Post-a-lot
type 3 was D-jet...it was a 1.6L though. might have some translation issues between models, but in therory it should work fine. that is as long as the trigger point signal occurs on the same points as the 2.0L one. I have a 2.0 dizzy for not much. pm me if you need.
b
Gint   My 2.0 runs on 2 cylinders (1 and 3 only)   Nov 4 2005, 05:43 PM
bmunday   Ok I got the fix... Get a pen and paper, write thi...   Nov 4 2005, 05:47 PM
SLITS   Gint...valves on 2 & 4 too tight (1st guess).... t...   Nov 4 2005, 06:04 PM
Gint     Nov 4 2005, 06:17 PM
onrails   f.i. trigger points? they fire two at a time. ...   Nov 4 2005, 06:21 PM
Brian_Boss   I would pull the spark plugs on the non firing cyl...   Nov 4 2005, 06:22 PM
bondo   Is there any chance the plug wires got swapped bet...   Nov 4 2005, 06:27 PM
Gint     Nov 4 2005, 06:29 PM
Gint     Nov 4 2005, 06:38 PM
bondo     Nov 4 2005, 06:56 PM
Aaron Cox     Nov 4 2005, 07:03 PM
vsg914   If you aren't dislexic(sp) about the 1432 ccw ...   Nov 4 2005, 07:43 PM
SLITS     Nov 4 2005, 08:20 PM
SGB   yep. I done that too, htt...   Nov 4 2005, 08:32 PM
Aaron Cox     Nov 4 2005, 08:34 PM
boxstr   Mike Doe's this car have the injector resistor...   Nov 4 2005, 11:20 PM
Gint     Nov 4 2005, 11:28 PM
Aaron Cox   too funny mike.... stupid shit that makes these c...   Nov 4 2005, 11:30 PM
Gint   ...and the muffler bearing. While I'm in ther...   Nov 4 2005, 11:32 PM
bd1308   upgrade to the O-Pipe and get the engine oil bypas...   Nov 4 2005, 11:52 PM
dlo914   slight hi-jack...would a 311 905 205 AE distributo...   Nov 5 2005, 02:12 AM
bd1308   type 3 was D-jet...it was a 1.6L though. might hav...   Nov 5 2005, 06:17 AM
Gint   I might be interested in it Britt. Can you tell m...   Nov 5 2005, 10:10 AM
bd1308   i have 2 1: the distributor that came with my car...   Nov 5 2005, 10:39 AM
Gint   OK, let me ask again, can you get me th epart numb...   Nov 5 2005, 10:42 AM
bd1308   I cleaned it out. I'll PM you part numbers soo...   Nov 5 2005, 10:44 AM
Gint   No that the rain has stopped I went out and swappe...   Nov 5 2005, 11:39 AM
bd1308   no dizzy needed then? b   Nov 5 2005, 11:49 AM
Gint     Nov 5 2005, 01:36 PM
bd1308   i'll get the part numbers..... and pics. b   Nov 5 2005, 01:47 PM
bd1308   on the original: 039 905 205A (B ) 0 231 174 011 ...   Nov 5 2005, 01:57 PM
Gint     Nov 5 2005, 03:02 PM
bd1308   the B part is the one with the Bosch symbol next t...   Nov 5 2005, 03:07 PM
Gint     Nov 5 2005, 06:20 PM
bd1308   http://reactornet.net/gallery/view_album.p...bumNa...   Nov 5 2005, 07:28 PM
SLITS   0 231 169 011 (also intechanges to 0 231 184 004) ...   Nov 8 2005, 11:25 AM
bd1308   ron..... no. the rebuilders used a core case, w...   Nov 8 2005, 12:49 PM
Triaddave   i had the same problem a few years ago. i would lo...   Nov 8 2005, 01:00 PM
Gint     Nov 8 2005, 05:34 PM
Gint   ...   Nov 8 2005, 05:36 PM
Joe Sharp   http://www.914world.com/bbs2/html/e...   Nov 8 2005, 09:39 PM
- Lo-Fi Version Time is now: 1st August 2025 - 10:06 AM
