6/carbs: ? about tall 2ndary venturi's, rich, I miss you. |
brant |
Nov 3 2005, 11:50 AM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Hi all... thanks for the help in advance. I want to try a set of the tall 2ndary's on my IDS-3C carbs. I'm running the stock ones and want to try the tall ones, that I've heard called "906-style" its a race car and withoug re-hashing all of my jetting and dyno history, my questions are: 1) pierce manifold says they have 2 different types in stock a 3.5 size and a 4.5 size. I believe this measurement is in reference to bore and not height. Pierce said that both sizes are the "tall" type. Which do I want? Motor is a 1967 2.0/S motor at altitude. (the pierce catalogue references that the IDS carbs came with 4.5 short, but I'd like confirmation before I order) 2) Does anyone know if these tall secondaries interchange on the IDA carb versus the IDS carb. I would assume so, but I once bought some F33 emulsion tubes from Pierce that do fit the IDA, and found that they would not fit the IDS. I didn't know there was that much difference between the two carbs, which surprised me. But again, before I order do people know if the 906-type tall 2ndaries will fit an IDS-3C body? again, thanks in advance everyone! brant |
Phoenix-MN |
Nov 5 2005, 08:25 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Back to the original question -
I'm running the taller version and they appear to be the 3.5's. My engine is 2.5L and jetted as follows; Main Vent. 32 mm Tall secondary vent. F26 emultion tubes 180 air correction jet 140 main jet 160 idle jet "Solex grind cams" This combination runs/pulls strong from 2000 to 7000 rpm without any flat spots or peaks. Hope this helps, Paul (oop's forgot to add I'm running IDA 3C carbs, IDS I belive are different for the accelerator enrichment output) |
Lo-Fi Version | Time is now: 10th June 2024 - 12:56 PM |
