> fuel cel vent (where?)
machina
post Aug 16 2003, 04:35 PM
installing fuel cel in forward compartment, was thinking about installing vent in the right forward parking light cutout.
where do other 914's and 911's with cel up front usually put the vent?
thanks,
dr
machina
post Aug 18 2003, 11:07 AM
the cel is fuel safe's top of the line pro cel. It has a check valve built into the vent port already.
I have heard to put it under the car and then been told absolutely no because you will get dirt into the cel.
The vent allows air to escape with expansion and filling and air to enter as the fuel is consumed.
Since some fuel may be purged out the vent when it is topped off, I didn't like the idea of locating the vent near the fender which is very close to a red hot rotor. Then I was thinking about using the hole from the radio antennae but it is right in front of the driver's door, don't want fuel in there either.
synthesisdv   fuel cel vent (where?)   Aug 16 2003, 04:35 PM
scotty   vent to the passenger compartment :evilgrin: ?   Aug 16 2003, 09:20 PM
ChrisReale   Or vent it to your helmet :o What about using the...   Aug 16 2003, 10:59 PM
synthesisdv   so if we go thru the firewall, can it vent down un...   Aug 18 2003, 05:37 AM
john rogers   If I remember correctly, the SCCA GCR's call f...   Aug 18 2003, 10:40 AM
synthesisdv   the cel is fuel safe's top of the line pro cel...   Aug 18 2003, 11:07 AM
Brad Roberts   Too much effort. Run the line from the tank thru t...   Aug 18 2003, 12:51 PM
synthesisdv   thanks brad, sounds good accept that the SCCA rul...   Aug 18 2003, 01:14 PM
ArtechnikA
- Lo-Fi Version Time is now: 1st July 2025 - 06:06 AM
