lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
I've read through a lot of the welder questions, and one topic regularly mentioned is 110 v 220, with "220 is better" usually being expressed.
Now, I can understand the amps v. volts v. power issue (power to actually melt something is measured in Watts, which is amps x volts. However, power through a wire is essentially amp-limited, and power through a household circuit is very much limited by the breaker, which is amp-limited). 110v x 20a is 2200W, where 220v x 20a is 4400W, so 220v definitely gives you more power. However, how much power do you actually NEED for car work? Most of the time, you'd be welding 16-20g sheet, except for things like engine mounts, cages, and the like, where you might use thick-walled tube, but still you're unlikely to use much over 1/8" wall, even for a cage. Aluminum welding would require more power, but (IMHO) would also really require TIG. So, for steel work using MIG, how much power do you really require? What's the highest amp setting normally seen when doing the kind of welding you'll see on a 914 (or any other typical car)? |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,833 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
It has to have gas to really be MIG. The I stands for Inert, and the G stand for Gas. Flux core wire welders are really a stick welder with a thin stick on a roll. I don't think you'll find a 220 MIG unit, that doesn't have gas. Does this tell you anything?
Like sj914 said, the length and gauge of the extension cord will effect the welding performance. So use the shortest ext. cord you can. You can weld anything you'll need on a 914 just fine with a 110 rig with a gas set up. Just get a good one, ie Miller, Hobart, Century, HTP, Lincoln. |
Lo-Fi Version | Time is now: 15th July 2025 - 05:41 AM |
