Yet another welder Q, 110 v 220 |
lapuwali |
Nov 7 2005, 04:25 PM
I've read through a lot of the welder questions, and one topic regularly mentioned is 110 v 220, with "220 is better" usually being expressed.
Now, I can understand the amps v. volts v. power issue (power to actually melt something is measured in Watts, which is amps x volts. However, power through a wire is essentially amp-limited, and power through a household circuit is very much limited by the breaker, which is amp-limited). 110v x 20a is 2200W, where 220v x 20a is 4400W, so 220v definitely gives you more power. However, how much power do you actually NEED for car work? Most of the time, you'd be welding 16-20g sheet, except for things like engine mounts, cages, and the like, where you might use thick-walled tube, but still you're unlikely to use much over 1/8" wall, even for a cage. Aluminum welding would require more power, but (IMHO) would also really require TIG. So, for steel work using MIG, how much power do you really require? What's the highest amp setting normally seen when doing the kind of welding you'll see on a 914 (or any other typical car)? |
Mueller |
Nov 7 2005, 07:43 PM
tells me it's just as cost effective to build a dual use/purpose machine when you get into the bigger amperage units, besides it's smarter for the companies to make one machine that can do 2 functions (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Flux core welding should not be looked down upon at all...for some jobs, the use of the MIG is better, but there will always be jobs where one tool is better than another.....personally, I like Flux-Core Wire welding for some of the side projects I've done lately....the inert gas would be a PITA due to wind and logistics. If Flux core welding was that bad, you'd think they wouldn't be offering so many different wire grades and options. |
Lo-Fi Version | Time is now: 10th June 2024 - 01:35 AM |
