lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
I've read through a lot of the welder questions, and one topic regularly mentioned is 110 v 220, with "220 is better" usually being expressed.
Now, I can understand the amps v. volts v. power issue (power to actually melt something is measured in Watts, which is amps x volts. However, power through a wire is essentially amp-limited, and power through a household circuit is very much limited by the breaker, which is amp-limited). 110v x 20a is 2200W, where 220v x 20a is 4400W, so 220v definitely gives you more power. However, how much power do you actually NEED for car work? Most of the time, you'd be welding 16-20g sheet, except for things like engine mounts, cages, and the like, where you might use thick-walled tube, but still you're unlikely to use much over 1/8" wall, even for a cage. Aluminum welding would require more power, but (IMHO) would also really require TIG. So, for steel work using MIG, how much power do you really require? What's the highest amp setting normally seen when doing the kind of welding you'll see on a 914 (or any other typical car)? |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Mike, something's wrong with the 110v machines you've been using. I've only used a Lincoln WeldPak 100 110v MIG up until recently. Wire size has a lot to do with how much power you can transmit. If you're using 0.023" or 0.025" wire, it's too small for thick material. The only time I think I'd need a 220v MIG is if I were welding 3/8" think or larger material. With the 100v I could get away with welding 1/8" stuff with the small wire, but for thicker stuff I'd use 0.035" flux core. So I say 110v for car work.
BTW, I love my TIG for body panels. Very workable welds. (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif) |
Lo-Fi Version | Time is now: 15th July 2025 - 05:18 AM |
