aircooledboy |
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest ![]() |
I have been turning a lot of wrenches lately, unfortunately on a 98 Olds Aurora with a 4.0 aluminum block "little Northstar". Had an overheating problem that I finally narrowed down to a head gasket issue.
Pulled the be-och out, got her apart, all checked out, and cleaned up. I get to putting the heads back on, and things go south. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) The head bolts are stretch bolts. 1st torque is to 30 lbs, then 70', 70', 60'. I get the first head on with each bolt torqued to the initial 30 lbs. When I went to do the first 70', the 2nd bolt spins. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Pull the head back off, put in a standard time-cert, try again. Get head back on, get all to 30, start to do 1st pass of 70', a different bolt spins. (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) I decide to see what the other head will do. Again, the 2nd bolt I try to turn to the initial 70' spins. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flipa.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) I didn't try any more. So, 2 questions: 1) should I just bite the bullet and just time cert all the head bolt holes. On the one hand, I don't see and good alternative, but I am just reluctant to drill what might be perfectly good threads out. on the other hand, the head gaskets are $50 a pair, and I have already ruined one set. 2) In doing some research on the net, it looks like GM's kit for this bull caca uses an allegedly different design of insert for the aluminum block than the standard time cert. Does it matter? An other input is greatly appreciated as always. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
phantom914 |
non-914-owner non-club member ![]() ![]() ![]() Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 ![]() ![]() |
I have not used Heli-coils in high strength applications. Strength should be OK though. In fact, aluminum is strong enough. The issue is when there is any slight seizing as the bolt is backed out. I think Heli-coils have a greater tendency to back out than time certs when you remove bolts that are slightly seized to the insert.
Andrew |
Lo-Fi Version | Time is now: 3rd September 2025 - 09:23 PM |
