RON S. |
9140430841, FINALLY RUNNING ![]() ![]() ![]() Group: Members Posts: 1,216 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States ![]() |
I gotta give a thanks to Aaron and all the others who passed on the info that 944 cv's and 914/4 axles are a much more wallet friendly alternitive to a custom made axle setup for a 914/6.
Everything work as indicated,with one exception. I chose to take the 944 stub axle,and machine the bearing contact area flat as the original /6 stub.With a small radius in the corner. I did this to get an additional .200" of free movement in the axle shaft,since I had to program up an adaptor for my 915 trans output flange.No spacer is used. ( HINT)Use a ceramic insert in your tool holder,and this is a less than 10 minute job. All said,I have about 3/4-1" of total axle float with everything locked down,and the car stiing level on pavement. Ron Attached image(s) ![]() |
Lo-Fi Version | Time is now: 1st August 2025 - 03:56 PM |
