> seatbelt buzzer wiring
r_towle
post Nov 8 2005, 06:30 PM
Custom Member
ok....we are in the assembly mode on my sons restoration.
Does anyone have a pic of the wiring under the passenger seat...
Specifically I am looking for how it is mounted to the floor and the correct position.
the system is already jumpered, but I would like to mount it the way it is supposed to be, that way it wont rattle loose or get caught in something else.
Rich
Dave_Darling
post Nov 10 2005, 09:49 PM
914 Idiot
QUOTE (double-a @ Nov 10 2005, 06:37 PM)
it looks a lot better than some of the other bypass setups i've seen though. how can i undo it?
Don't. You really don't want this thing to be fully operational--it is one more potential failure point for your starter circuit. It's yet one more place you can be losing voltage going to the starter, which is pretty much the last thing you want to happen. It's also stupid to require the seat belt to be fastened before you can start the car. Just... stupid.
If you want it to look original, then replace the main wiring harness so you will have all un-cut wires. If that's too extreme, solder the wires together and cover with shrink-tubing. Use more (large diameter!) tubing to encase all of the wires past the point where they are spliced, thus hiding the splices from view. But I'd have the yellow starter wire there just be a dummy, and have the yellow and yellow/red wires spliced together out of view.
Otherwise you (or the next owner of your car) will be back here in a few years, asking about "hot start relay kits" and other starter fixes...
--DD
r_towle   seatbelt buzzer wiring   Nov 8 2005, 06:30 PM
r_towle   http://www.914world.com/bbs2/h...   Nov 8 2005, 11:17 PM
double-a   i could get a clue on this as well. i have two set...   Nov 8 2005, 11:52 PM
mercdev   I'm not 100% sure since my car has had other P...   Nov 9 2005, 12:07 AM
jim_hoyland   Ditto: I'm also looking to restore the origina...   Nov 9 2005, 08:24 AM
2-OH!   Sorry guys, all 3 of my previous restorations, I d...   Nov 9 2005, 02:23 PM
dsmeyer   Just happen to have my '76 project car right h...   Nov 9 2005, 05:01 PM
dsmeyer   A little more detail...   Nov 9 2005, 05:02 PM
Aaron Cox   wierd. i have a FAT relay under there.. like 2 or ...   Nov 9 2005, 05:21 PM
dsmeyer   ...   Nov 9 2005, 05:35 PM
2-OH!   Yep, the fat relay lookin' do-dad is the seat ...   Nov 9 2005, 05:36 PM
lagunero   where all models fit with a relay that size? The P...   Nov 9 2005, 06:13 PM
jim_hoyland   Nice picture; maybe we can get a good pic of the 2...   Nov 9 2005, 09:33 PM
double-a   here's how the relay/wires look in my '75....   Nov 10 2005, 12:06 AM
double-a   here's another look, a bit closer. ~a   Nov 10 2005, 12:08 AM
jim_hoyland   Nice pic of the '75; I'm going to check mi...   Nov 10 2005, 09:26 AM
ejm     Nov 10 2005, 06:53 PM
double-a     Nov 10 2005, 08:37 PM
jim_hoyland   Mine was worse than I thought. First, the dash sea...   Nov 10 2005, 09:22 PM
Jeff Bowlsby   Here you go guys, I hope this helps. This wiring d...   Nov 10 2005, 09:42 PM
Dave_Darling   ...   Nov 10 2005, 09:49 PM
double-a   ok, i'll just leave it as-is, since the two wi...   Nov 10 2005, 10:05 PM
jim_hoyland   Dave, Your point is well taken; you are right abou...   Nov 10 2005, 10:51 PM
ejm   Scotch locks suck as a reliable way to make a conn...   Nov 11 2005, 01:18 AM
jim_hoyland   This may be a dumb question, but I really don...   Nov 11 2005, 08:44 AM
Rleog   This may be a dumb question, but I really don...   Feb 28 2013, 07:58 AM
Jeff Bowlsby
  Nov 11 2005, 08:48 AM
r_towle   this diagram from Bowlsby should be in the classic...   Nov 23 2005, 08:29 PM
double-a     Nov 23 2005, 08:43 PM
jim_hoyland   I've been wondering how the relay worked. My o...   Nov 23 2005, 10:02 PM
r_towle   I was just informed that it may be that these have...   Nov 23 2005, 10:38 PM
jim_hoyland   Now we're getting somewhere ! Really looki...   Nov 23 2005, 11:06 PM
MecGen   You Guys http://www.914w...   Nov 24 2005, 06:56 AM
jim_hoyland   Exactly ! When we know how that thing works, t...   Nov 24 2005, 08:22 AM
r_towle   ok..,.,. I have delivered a complete wired up rel...   Nov 24 2005, 05:24 PM
grasshopper   well??? http://www.914world.com/bbs...   Nov 27 2005, 12:34 PM
Carlitos Way   I'm not sure where I read this.. or if it is a...   Nov 27 2005, 04:50 PM
grasshopper
- Lo-Fi Version Time is now: 9th June 2026 - 07:08 PM
