> oil cooler line sizes, what AN sizes for fittings
DanT
post Nov 10 2005, 10:11 PM
Going back to the Dark Side!
Will be installing an oil cooler up front when the car comes back from paint.
With the plan of doing a six conversion in a year or so, what size cooler, lines and fittings would you all suggest.
I am not as concerned with the cooling for the 4...but want to make sure I have plenty of cooling capacity once I do the conversion. Car is used for AX, DE and TT
We run in the summer at Th and BW where it can be 105+ in the shade.
What suggestions do you have?
(IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif)
DanT
post Nov 10 2005, 11:19 PM
I was referring to the fact that I want the cooler set up to be optimal for a 6. Yes, I want the 4 to be cooled, but that is not my primary goal. Even if it appears to be overcooled at the present.
Even if I were not planning on a 6 conversion I would be putting on a good size cooler, I know after having other 4s and a 6 that the cooling is very important.
I mean that for the 4 it may appear to be overkill and that is OK.
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Dan (Almaden Valley)   oil cooler line sizes   Nov 10 2005, 10:11 PM
Aaron Cox   do a search. common knowledge is -8 for a 4, im ru...   Nov 10 2005, 10:12 PM
0396   _16   Nov 10 2005, 10:52 PM
trekkor   Oil cooler -BIG lines -12 -16 from the oil tank t...   Nov 10 2005, 11:11 PM
Dan (Almaden Valley)   Trekkor, Could you post (repost?) pics of your var...   Nov 10 2005, 11:14 PM
trekkor     Nov 10 2005, 11:15 PM
trekkor   Certainly! Setrab approx 23wx2dx5t
  Nov 11 2005, 04:08 PM
- Lo-Fi Version Time is now: 1st August 2025 - 05:03 PM
