> What should be attached to this?
Buckeye '73
post Nov 10 2005, 07:22 PM
This is the passenger speaker.
Is the blue thing in the bottom of the picture a ground?
What was originally hooked up to it?
Thanks,
Bryce
Elliot_Cannon
post Nov 10 2005, 11:19 PM
Group: Retired Members
QUOTE (Buckeye '73 @ Nov 10 2005, 06:35 PM)
a good sign that there may be more problems under the dash. The Cap'n
Uh... Yeah....
No turn signals or horn...
Apparently there was some re-wiring done. (Note the new bus fuses in this picture.) (Also, the stupid SO% didn't have the sense to replace the fuse cover.... I spend 5 mins picking up fuses every morning...)
Check resources, parts and products for some great after-market fuse blocks.
Cheers, Elliot
Buckeye '73   What should be attached to this?   Nov 10 2005, 07:22 PM
Aaron Cox   not stock. someone tried to use it as a ground it ...   Nov 10 2005, 07:25 PM
bondo     Nov 10 2005, 07:35 PM
Hammy   For the horn, slowly twist off the rubber horn pad...   Nov 10 2005, 07:43 PM
jd74914   if the spring on the horn connection was pushed ou...   Nov 10 2005, 09:48 PM
- Lo-Fi Version Time is now: 15th April 2026 - 10:14 AM
