| GaroldShaffer |
Nov 11 2005, 11:11 AM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,645 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
While going to the FFC this year we did drive in some rain. I have a GT lid on my car and while at the FFC myself and a few others noticed I had standing water in the hell hole. With Battery & ECU in the way it was hard to find the drain hole to unplug it so I just soaked up the water with a rag.
Fast forward to today while preping the car for winter I removed the battery and move the ECU out of the way to get a better look and there is NO drain hole? There is one on the driver side. There should be one right? I went under the car and I do not see one. Where I think one should be the fuel pump is there, so...... should there be one? My car is 70 model if that matters. I plan to drill a hole anyways but found it odd that there isn't one. |
| watsonrx13 |
Nov 11 2005, 12:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Here's a shot of the drain hole from underneath the engine shelf. This is how I held the bottom section of the engine shelf down while I welded it into place. If you have the engine out, I would recommend drilling from the bottom up.
Also, here's the link to my website showing the installation of the engine shelf. Attached image(s)
itsa914 There should be a water drain hole Nov 11 2005, 11:11 AM
jet1 there should be one right where the engine shelf m... Nov 11 2005, 11:19 AM
Midtowner Maybe it's crusted over. It's there. Or,... Nov 11 2005, 11:21 AM
RON S. It should have one.However if the shelf had at any... Nov 11 2005, 11:24 AM
bd1308 what were you poking at then at the FFC?
hey i ca... Nov 11 2005, 11:25 AM
itsa914 Nov 11 2005, 11:34 AM
Bleyseng the drain hole is on the left in this pic Nov 11 2005, 11:50 AM
itsa914 Heading out to drill the drain hole, just need to ... Nov 11 2005, 12:05 PM
SirAndy Nov 11 2005, 12:10 PM
Eric_Shea Make sure you drill it from underneath or right wh... Nov 11 2005, 05:23 PM
McMark And if your fuel pump is there watch out for it. Nov 11 2005, 05:26 PM
trekkor When I did mine last year I made a long slot so th... Nov 11 2005, 06:53 PM
itsa914 ![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 06:08 PM |
