| YksKrad |
Nov 12 2005, 10:32 AM
Member ![]() ![]() Group: Members Posts: 72 Joined: 14-February 05 From: Rolla, MO Member No.: 3,602 Region Association: Upper MidWest |
Okay, first things first, I'm on a budget that is basically non existent, so I need to know where toget the best rebuild kit for my buck.
Stock rebuild on a 76' carbed 2.0... I'm basically look for valves, springs, rings, seals, and bearings as cheap as possible... Also are there any types of sealants that wouldn't be found in a rebuild shop that I might need? |
| Bleyseng |
Nov 12 2005, 12:45 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Cheap valves? you can use Stainless steel valves BUT the seats and guides need to be replaced by a PRO. The valve seats tend to fall out if not done properly and witha few tricks.
A cheapo rebuild shop can and will crack and or ruin a set of 2.0l heads as they are fragile when installing new guides. Most 2.0l heads suffer from cracks from the spark plug hole to the valve seats and it needs to be drilled out and welded up. Len at HAM or Adrian at Headflowmasters are the shops I would recommend for headwork. bearings and rings and all can be had from Jake's store, PP, GPR etc. |
YksKrad Best engine rebuild kits? Nov 12 2005, 10:32 AM
gregrobbins ![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 05:47 PM |
