TINCAN914 |
Summer's Commin... ![]() ![]() ![]() ![]() Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains ![]() |
It's been a serious pain in the A double S but in the long run, it will be worth it...
Just thought I would share a few pictures. I must have removed 50 lbs of bondo... I think the PO had stock in the stuff.. Still not quite sure why it was used? The doors look straight... Anyone have any thoughts? Other then an accident, I can't think of any other reason. Attached image(s) ![]() |
TINCAN914 |
You guys are probabely right.
At first I thought that since there seems to be paint coat on top of paint cost. Perhaps they used the bondo to fill the cracked layers between each coat. The bondo dhow is about 1/2 of what there was.I was coming off in sheets, when I soaked it with stripper and then took the putty knife to it... Scott... Here is a stuoid question: I am thinking I might be able to paint it in the next month or so, but with X-mas coming I might need to wait. Should I be concerned with moisture? I know I'm not talking aobut 6 months on the East coast, but after the work I have put in, it does worry me. If so should it be primered? I don't have a spray gun, so the quality of the paint job would be poor at best. Second if I should primer it, what type of primer should I use? Thanks |
Lo-Fi Version | Time is now: 15th July 2025 - 06:16 AM |
