toon1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 ![]() |
I was just going to replace the p/r tube seals and thought, since I dont know the history of the motor ,I shoud pull the heads and check things out to make sure the thing is even worth using. With all the bolts off ,I pulled the head and then proceeded to pull the two screws that hold the tin on the c/c. while lifting the screw up the washer fell into the lifter hole and DINK!, DINK ! you gussed it ,right into the case.
So now what, is there any way to get it out without splitting the case? Can I leave it there? |
toon1 |
The more I look at it ,the more I think it needs to be rebuilt. After further inspection the cam is in real bad shape, the rear lobe is worn badly.
Who makes the best manuels for a rebuild, I heard benltly's where good? |
Lo-Fi Version | Time is now: 15th July 2025 - 03:50 AM |
