| mikelsr |
Nov 13 2005, 09:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 657 Joined: 2-January 05 From: Mahomet, IL Member No.: 3,390 Region Association: Southwest Region |
I installed a short shifter and I when I went to test it I found that I can't get into 4th or 5th gear because the extended shifter now hits the cluch cable tube. I have rotated the shift bar to try and compensate for the new length with little success. Any ideas?
TIA, Mike |
| ChrisFoley |
Nov 13 2005, 07:15 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,032 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
When this happened to me I discovered that the clutch cable tube was no longer connected to the tunnel at the front the way it is supposed to be. Once I re-attached the tube to the side of the tunnel the contact went away.
mikelsr short shifter Nov 13 2005, 09:58 AM
Cap'n Krusty Rotating a straight rod doesn't result in much... Nov 13 2005, 10:22 AM
mikelsr I had thought about raising it up. Thanks. Nov 13 2005, 10:31 AM
r_towle I had the weltmeister kit (which I have since remo... Nov 13 2005, 10:45 AM
Dr Evil I have the Weltmeister kit currently and the space... Nov 13 2005, 05:16 PM
mikelsr Thanks. I put some 10mm spacers in and still neede... Nov 13 2005, 05:19 PM
mikelsr Thanks for the info. I did look at the clutch cabl... Nov 14 2005, 09:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th September 2026 - 02:59 AM |
