> shaky suspension ?, all new but still slight shiver
michelko
post Nov 1 2005, 10:53 AM
Hi everybody,
have a mysterious suspension problem.
Sometimes on a bumpy road the car is shaking a bit side to side.
Changed the tie rods to turbo style, mounted bump steer kit, adjusted the toe in to factory spec, every screw connection is fastened. what else can i do (check)?
Any body know this problem or the remedy?
I am sure it is not the bump steer problem!!!
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif)
michelko
post Nov 14 2005, 12:30 PM
QUOTE (Spoke @ Nov 13 2005, 08:31 PM)
Had the wandering thing also. Tie rod ends were shot, replaced with turbo tie rods, wandering reduced but not gone. Checked front end by jacking up one side at a time, and grabbing the wheel, shake back and forth, up and down and found out the ball joints were bad.
After new ball joints, things got much better, but still had some play which was from the wheel bearings not being tight enough. Tightened the bearings and now the car is nice and tight.
Spoke
maybe that balljoint way is something i could try out bevore i throw it away (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) . they are not too expensive.
michelko   shaky suspension ?   Nov 1 2005, 10:53 AM
Aaron Cox   was it aligned afterword? is your car lowered? th...   Nov 1 2005, 10:58 AM
Joe Ricard   Define shaky. like going over bump in curve and t...   Nov 1 2005, 11:04 AM
michelko   it feels like the whole front of the car is moving...   Nov 1 2005, 11:15 AM
lagunero   lug nuts tight? new tires grabbing grooves of road...   Nov 1 2005, 11:18 AM
SLITS   Rain grooves in driving surface? Shitty roads Po...   Nov 1 2005, 11:19 AM
michelko   tires are new. wheel bearings not checked till no...   Nov 1 2005, 11:39 AM
michelko   a forgot: anti roll bar in, no difference!   Nov 1 2005, 11:41 AM
goose2   shocks?   Nov 1 2005, 12:30 PM
Headrage   Bent wheel?   Nov 1 2005, 12:31 PM
SLITS   <...   Nov 1 2005, 12:54 PM
Joe Ricard   Yea, I agree now it sounds like you need to go in...   Nov 1 2005, 01:06 PM
Thorshammer   How wide are the front wheels and where is the cas...   Nov 1 2005, 01:32 PM
r_towle   I chased a shimmy for quite a while... I changed ...   Nov 1 2005, 04:55 PM
michelko     Nov 1 2005, 11:33 PM
michelko   After some inspection of the suspension parts, cha...   Nov 13 2005, 01:58 PM
r_towle   vertical wheel shake on the front tires is the bal...   Nov 13 2005, 05:41 PM
Spoke   Had the wandering thing also. Tie rod ends were sh...   Nov 13 2005, 10:31 PM
michelko     Nov 14 2005, 12:30 PM
Eric_Shea   Hey Rich... Check this out! I agree with Rich...   Nov 14 2005, 12:39 PM
michelko   purchased already a set of new wheel bearings. Thi...   Nov 16 2005, 11:29 AM
Brotherbob   I would mount the rear tires on the front and fron...   Nov 16 2005, 11:36 AM
michelko   ...   Nov 28 2005, 08:09 AM
michelko     Nov 28 2005, 08:32 AM
Aaron Cox   where do you get your parts? do you go down to mit...   Nov 28 2005, 10:44 AM
michelko     Mar 24 2006, 08:35 AM
rhodyguy   brad told me to cut the bump stop in half. liberal...   Mar 24 2006, 10:31 AM
Dr Evil   I use a pipe wrench and then put gobs of anti siez...   Mar 24 2006, 10:38 AM
DEC   Michael, call me http://www....   Mar 24 2006, 10:51 AM
SirAndy   ...   Mar 24 2006, 11:43 AM
michelko   <...   Mar 25 2006, 12:25 AM
- Lo-Fi Version Time is now: 2nd May 2026 - 04:25 AM
