| r_towle |
Nov 15 2005, 06:35 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
On a stock US 2.0 liter with the dished pistons...
If the head gasket is removed...no cylinder base gasket is installed. What is the new compression ratio...circa??? Do the valves have a chance of hitting the top of the piston... I have not doe this, so I dont know what it looks like yet...just want to see if someone knows already... Rich |
| Dr. Roger |
Nov 15 2005, 07:00 PM
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
i've seen those valve to piston clearances get to almost nothing on factory cars. ford probe for one using interference engines. no problems as long as the timing belts are good. a non issue for 914's.
just bolt it all up and hand crank it slowly. if it goes round and round you're probably alright. just don't plan redlining it or my opinion becomes null and void. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
r_towle CR/Interferience question Nov 15 2005, 06:35 PM
Aaron Cox rich -
im in the same boat.
pulling the heads to ... Nov 15 2005, 06:36 PM
SLITS Engineers.....sheeeeesh
http://www.csgnetwork.com... Nov 15 2005, 06:47 PM
Aaron Cox i dont know my deck height.... yay. more stuff to ... Nov 15 2005, 06:51 PM
Mark Henry Measure measure MEASURE!!!!!
r_towle so your saying that stock pistons stick out of the... Nov 15 2005, 07:02 PM
Mark Henry http://www.914world.com/bbs2/html/... Nov 15 2005, 07:05 PM
Mark Henry <... Nov 15 2005, 07:10 PM
SLITS If your really hot....
bring pistion to absolute ... Nov 15 2005, 07:15 PM
Mark Henry BTW if you take out the head gasket most likely yo... Nov 15 2005, 07:15 PM
nebreitling you definitely want to cc your heads and (re)set y... Nov 15 2005, 07:35 PM
r_towle Nov 15 2005, 07:38 PM
r_towle Let me ask a detailed question.
Does the CR in an... Nov 15 2005, 07:45 PM
SLITS I also would coat the head and clay with a little ... Nov 15 2005, 07:55 PM
Aaron Cox so. ron, ill bring my motor by, and we can do this... Nov 15 2005, 07:56 PM
SLITS <... Nov 15 2005, 08:49 PM
type47 CR is about 7.6:1 + or - alot. stock CR was 7.6 ac... Nov 15 2005, 09:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 10:45 PM |
