| r_towle |
Nov 15 2005, 06:35 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
On a stock US 2.0 liter with the dished pistons...
If the head gasket is removed...no cylinder base gasket is installed. What is the new compression ratio...circa??? Do the valves have a chance of hitting the top of the piston... I have not doe this, so I dont know what it looks like yet...just want to see if someone knows already... Rich |
| type47 |
Nov 15 2005, 09:28 PM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
CR is about 7.6:1 + or - alot. stock CR was 7.6 according to factory specs
r_towle CR/Interferience question Nov 15 2005, 06:35 PM
Aaron Cox rich -
im in the same boat.
pulling the heads to ... Nov 15 2005, 06:36 PM
SLITS Engineers.....sheeeeesh
http://www.csgnetwork.com... Nov 15 2005, 06:47 PM
Aaron Cox i dont know my deck height.... yay. more stuff to ... Nov 15 2005, 06:51 PM
Mark Henry Measure measure MEASURE!!!!!
Dr. Roger i've seen those valve to piston clearances get... Nov 15 2005, 07:00 PM
r_towle so your saying that stock pistons stick out of the... Nov 15 2005, 07:02 PM
Mark Henry http://www.914world.com/bbs2/html/... Nov 15 2005, 07:05 PM
Mark Henry <... Nov 15 2005, 07:10 PM
SLITS If your really hot....
bring pistion to absolute ... Nov 15 2005, 07:15 PM
Mark Henry BTW if you take out the head gasket most likely yo... Nov 15 2005, 07:15 PM
nebreitling you definitely want to cc your heads and (re)set y... Nov 15 2005, 07:35 PM
r_towle Nov 15 2005, 07:38 PM
r_towle Let me ask a detailed question.
Does the CR in an... Nov 15 2005, 07:45 PM
SLITS I also would coat the head and clay with a little ... Nov 15 2005, 07:55 PM
Aaron Cox so. ron, ill bring my motor by, and we can do this... Nov 15 2005, 07:56 PM
SLITS <... Nov 15 2005, 08:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 12:14 AM |
