> CV questions, 5-lug
TonyAKAVW
post Nov 15 2005, 03:51 PM
That's my ride.
I have been readin up on the 944 CV joint threads and thought to myself... "I wonder what stub axles my car has." Right now the project car has an unfinished rear setup. There are early 911 hubs (according to P.O.), and some vented rotors, bearings, and some kind of stub axle. In addition there are some 944 drum brake parts installed.
I have no idea what kind of stub axle they are since they are installed. However, they do have 6 threaded holes. How can I tell what type of stub axles I have? Is there a measurement that I could make, for instance the diameter of the rin gon which the holes sit?
If I have early 911 stub axles, whay then can I do for a CV joint?
Also, if I end up having to ditch the 911 early stub axles (IF thats what they are) then can I do the 944 setup on the wheel end of the driveshaft only?
-Tony
eeyore
post Nov 16 2005, 08:50 AM
Those may be mid '74-'75 911 stubs like I have. They should fit in a 914 trailing arm, but you'll need some spacers to make them work (Patrick Motorsports parts PMPCASPI & PMPCASPO)
- Lo-Fi Version Time is now: 4th July 2025 - 03:19 AM
