> shaky suspension ?, all new but still slight shiver
michelko
post Nov 1 2005, 10:53 AM
Hi everybody,
have a mysterious suspension problem.
Sometimes on a bumpy road the car is shaking a bit side to side.
Changed the tie rods to turbo style, mounted bump steer kit, adjusted the toe in to factory spec, every screw connection is fastened. what else can i do (check)?
Any body know this problem or the remedy?
I am sure it is not the bump steer problem!!!
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif)
michelko
post Nov 17 2005, 06:13 AM
QUOTE (Brotherbob @ Nov 16 2005, 09:36 AM)
I would mount the rear tires on the front and front on the rear and drive it.
Nothing changes nothing lost , no money spent?
Then start throwing around parts money, wheel bearings, ball joints, etc.
my 2 centavos.
I have this shaky feeling since i bought the car.
It was fitted with 41/2" Steel Wheels with gigantic 165 winter-Tires, now 51/2 wheels with 185 summer-tires : no change (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
totaly shot boge shocks allaround, now new koni: no change (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
rusted through hell hole and rocker, now complete solid tub: no change (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
old standard tie rods, now new turbo-tie rods: no change (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
different toe in settings tested: no change (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif)
Things to check or change:
Ball-joints
wheel bearings
A-Arm bushings
Will do this next weekend
michelko   shaky suspension ?   Nov 1 2005, 10:53 AM
Aaron Cox   was it aligned afterword? is your car lowered? th...   Nov 1 2005, 10:58 AM
Joe Ricard   Define shaky. like going over bump in curve and t...   Nov 1 2005, 11:04 AM
michelko   it feels like the whole front of the car is moving...   Nov 1 2005, 11:15 AM
lagunero   lug nuts tight? new tires grabbing grooves of road...   Nov 1 2005, 11:18 AM
SLITS   Rain grooves in driving surface? Shitty roads Po...   Nov 1 2005, 11:19 AM
michelko   tires are new. wheel bearings not checked till no...   Nov 1 2005, 11:39 AM
michelko   a forgot: anti roll bar in, no difference!   Nov 1 2005, 11:41 AM
goose2   shocks?   Nov 1 2005, 12:30 PM
Headrage   Bent wheel?   Nov 1 2005, 12:31 PM
SLITS   <...   Nov 1 2005, 12:54 PM
Joe Ricard   Yea, I agree now it sounds like you need to go in...   Nov 1 2005, 01:06 PM
Thorshammer   How wide are the front wheels and where is the cas...   Nov 1 2005, 01:32 PM
r_towle   I chased a shimmy for quite a while... I changed ...   Nov 1 2005, 04:55 PM
michelko     Nov 1 2005, 11:33 PM
michelko   After some inspection of the suspension parts, cha...   Nov 13 2005, 01:58 PM
r_towle   vertical wheel shake on the front tires is the bal...   Nov 13 2005, 05:41 PM
Spoke   Had the wandering thing also. Tie rod ends were sh...   Nov 13 2005, 10:31 PM
michelko     Nov 14 2005, 12:30 PM
Eric_Shea   Hey Rich... Check this out! I agree with Rich...   Nov 14 2005, 12:39 PM
michelko   purchased already a set of new wheel bearings. Thi...   Nov 16 2005, 11:29 AM
Brotherbob   I would mount the rear tires on the front and fron...   Nov 16 2005, 11:36 AM
michelko   ...   Nov 28 2005, 08:09 AM
michelko     Nov 28 2005, 08:32 AM
Aaron Cox   where do you get your parts? do you go down to mit...   Nov 28 2005, 10:44 AM
michelko     Mar 24 2006, 08:35 AM
rhodyguy   brad told me to cut the bump stop in half. liberal...   Mar 24 2006, 10:31 AM
Dr Evil   I use a pipe wrench and then put gobs of anti siez...   Mar 24 2006, 10:38 AM
DEC   Michael, call me http://www....   Mar 24 2006, 10:51 AM
SirAndy   ...   Mar 24 2006, 11:43 AM
michelko   <...   Mar 25 2006, 12:25 AM
- Lo-Fi Version Time is now: 2nd May 2026 - 04:23 AM
