Chevy 350 or 327, Can someone give me a dimension? |
nick mironov |
Nov 20 2005, 10:59 AM
nickm Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 |
Can anyone give me a measurement of the distance between the crankshaft face and the engine mounting flange for either a Chevy 350 or a 327 - if you have one out of a car?
I have a 283 and suspect that its configuration might be a bit different from the 350s and 327s that most of the conversion adapter plates are set up for. Note the bevel in the end of the crankshaft socket. I understand that 350s do not have such a bevel. A standard pilot bearing does not fit into the beveled receptacle - the bearing's back face must be beveled to match. (My 283 has a dimension of 43/64" - just a shade over 5/8") Attached image(s) |
Type 4 Unleashed |
Nov 20 2005, 07:11 PM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
All, the outer dimensions on SBC are the same, 283, 302, 307, 327, 350. IN, your picture, the pilot bearing is already installed. Skline, has a 283 in his Chalon,Kennedy Adaptor. |
Lo-Fi Version | Time is now: 10th June 2024 - 03:37 PM |
