DAPO or factory, Throttle tube liner |
Joe Ricard |
Nov 22 2005, 06:06 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
So the throttle cable decides to stick yesterday morning. What the %^$%&$$
So didn't take it to work. Got home last night and started looking. Decided that the cable was the culprit not the CB linkage. Tried pulling string through as old cable came out. Turns out the cable end won't got through the tube. More *&^^%^** and ended up breaking the end off the cable as I pulled. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) There is a plastic liner indie the tube that wouldn't let it pass. White liner is pretty stuck but managed to push some of it up the tube but not far enough to grab from front of tunnel. About then my fingers were numb and it got real cold out AND dark. So I am deleting the liner I guess, and applying a good coat of grease to the cable. IF the liner is supposedto be there How the hell do you get the cable through? |
Root_Werks |
Nov 22 2005, 10:15 AM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
That liner comes on the cable. it's not part of the car, remove it. When you buy a new cable, it should have that plastic liner on it. If it doesn't, go buy one that does.
What happened is your cable over time started to break the little threads one by one. There is enough of them in there now they have bunched up and jammed in your tube. Push everything out however you can, get the tube free and clear. Slip in a new cable WITH a plastic cover over the cable part of it and all will be well again. Seen it a dozen times. Someone will come in with a sticking throttle..... |
Lo-Fi Version | Time is now: 1st June 2024 - 03:54 PM |
