help...., Rebuilding weber 32/36 dfa 23a 2l |
Oliver |
Nov 23 2005, 06:35 PM
Member Group: Members Posts: 66 Joined: 7-May 05 From: Portland, Or Member No.: 4,038 |
I have the carb out what next? any one have advise or web cite that shows ho to do this.... (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
Oh I know carbs Progressive carbs suck but that was what was on it and in the trunk a box of FI:shit:...PO could not get ti to work so he put on a Progressive kit used of ebay arout 2000 .... Attached image(s) |
eg914 |
Nov 24 2005, 01:43 AM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
You have a 32/36 DFEV. The E is for electric choke. The A would be for a water temperature controlled choke (not much use for us). I am also cursed with this carb by the PO. I just picked up a rebuild kit today at Bugformace in Sacramento. Guess what I will be doing this weekend? The carb can be made to work OK during warm weather, but is totally lame when the air temperature drops to below 50 degree F. If you go to www.redlineweber.com you will find a tech sections with some information on adjustment and bench assembly.
Good Luck! |
Lo-Fi Version | Time is now: 10th June 2024 - 02:41 AM |
