OK, after this long weekend, what did you get done to your car? |
URY914 |
Nov 27 2005, 08:24 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I worked on the left side bodywork. I'm trying to get the body panels to line up so I can get this thing painted. I've revised the mounting points and cut/filled with f-glass both lids to match up with the side piece. PITA:angry:
What did you do? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Attached thumbnail(s) |
Bleyseng |
Nov 28 2005, 08:17 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Fri. Installed the HE's after cleaning the oily grime off them. Then we installed the Bursch muffler. Finished up the alternater stuff from under the car and run the wires to the starter. Blair was drying out the Black car's pans and trying to remove the tar and see how much rust is there is. Its not to bad, maybe a 2" x 4" section
Sat. Worked on the drivers side front strut, installing the Koni shock, replacing the brake line. Went back to the engine and replaced the FI fuel lines at the injectors, installed some more tin, painted some more and then tuned the Westy (bad points). |
Lo-Fi Version | Time is now: 11th June 2024 - 02:05 AM |
