> another fuel line question-, would this work, why or why not?
ottox914
post Nov 28 2005, 07:29 PM
The glory that once was.
I was using NAPA fuel injection hose to replace some lines to the fuel injectors. Ran out. NAPA was out also. Went to another shop for more hose. They sold me some "multi use" hose, said it was good to 300 psi, could be used for fuel, hydrolic (SP?), or other liquids, and BONUS, it was less than 1/2 the cost of the "real" FI hose from NAPA. Have had no issues with it so far.
So, can I use this hose from the tank to the motor? Why or why not? It'd be flexable, to snake thru the tunnel if you wanted to go that way... or thru the long... (my car has headers and no heat thru the long), or route it along side the long like oil cooler lines... or inside the car next to the tunnel and put a metal cover over it?
Waddya all think?
SLITS
post Nov 28 2005, 09:38 PM
"This Utah shit is HARSH!"
Reasons for running braided or metal lines is chafing from vibration. If you are willing to inspect the rubber lines through the tunnel / longs as often as you check the lines in the engine compartment....ain't no problem.
- Lo-Fi Version Time is now: 6th July 2025 - 01:28 PM
