Black/purple Tach Wire..question, using an MSD.. (w/six engine) |
DougC |
Nov 28 2005, 04:55 PM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
The Black/Purple wire usually (4 cyl stock) goes to the "-" side of the coil, right? So I have my MSD unit hooked up and the car (6 cyl, MSD) idles and runs fine but the tachometer isn't working.. actually the blk/pur wire isn't hooked up right now either. So, I have a tach adapter and I'm assuming that the "-" wire from it will go to the neg side of the coil with the blk/pur wire from the harness. Does that sound logical? I've researched this quite a bit today so any insite would be appreciated.
Doug C |
Aaron Cox |
Nov 28 2005, 10:19 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i did the same thing......
here is what you ned to do. tach mod, or get a tach adapter..... jumper the initial signal resistor inside the tach... black wire in center of picture.... |
Lo-Fi Version | Time is now: 9th June 2024 - 07:20 PM |
