Mugs914 |
"Hey, yellow IS faster!" ![]() ![]() ![]() Group: Members Posts: 618 Joined: 22-July 05 From: Temple TEXAS Member No.: 4,452 Region Association: Southwest Region ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/calvin.gif) A bit of progress on the turbo project...
The rear suspension bits have been finished and installed. All I need now is a pair of 930 stub axles (six 10mm bolts). Anyone have any they'd like to part with? The rear arms have been reinforced with a 1" tube running diagonally through the arm from the bearing carrier to the pivot tube. See the pics, it takes too long to describe... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Also made the typical toe adjustment struts that run from the mouting bracket to the tub. The front fenders have been (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) to make way for the new nose. Even more weight out of the tub! (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) The one piece nose is the same as used on the Baker IMSA GTU car in the early eighties and it is LIGHT! We have access to the mold and will make anew one, but the original will do for now. Enough jawin' already. Here are some pics... The front minus fenders. There is still a bit of more metal to remove... The jack is holding the wheel at the approximate ride height. Attached image(s) ![]() |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
I'm not Mike but... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) the link offers some reinforcement and it will allow you to take the rear suspension apart without the need to realign it when you put it together the set lenght of the link "remembers" your toe setting |
Lo-Fi Version | Time is now: 10th June 2024 - 10:48 AM |
