| bperry |
Dec 2 2005, 01:50 PM
Lurker ![]() ![]() Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
So I finally did my first engine drop. What a PITA.
Hadn't been removed since late 80's. Had to soak things with PB blaster for 3 days and use a gear puller with some custom fabbed pieces to get the shift rod loose. Anyway, take a look at the picture. I guess I need to replace the gaskets, (not sure how hard that is). Any possiblity that his could be due to improper torqing? Or in a really odd case, could it actually be engine oil? The bottom of the transmission was pretty caked. The oil is like hardened tar. Not too much smell. Smells more like oil to me than trans fluid. But the car has been sitting for the past 8 years so there isn't too much smell. The reason that I ask is that when I took off the drivers side CV joint there was no CV gasket! Really! there was one on the passenger side but not on the drivers side. Kind of makes suspect alot of stuff. Also, this tail housing has had the "ears" welded back on. Could a slight misalignment cause uneven pressure that could these gaskets to leak? Thanks, --- Bill Attached image(s)
Lo-Fi Version | Time is now: 7th December 2025 - 10:36 PM |
