bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
Ok, I've got a 914, with an unknown engine (serial is for RoW 1.7) that was rebuilt "several years ago". Just now I was shuffling cars... started it up, backed it down the driveway. I let it warm up for a couple minutes and shut it off. Then I went to move the MG so I would have toom to park the 914 next to it. The 914 was off for maybe 5 minutes. When I went to start up the 914, it immediately had a loud clack/knock. I drove it up the driveway and parked it next to the MG, and it made the noise the whole way. (about 75 feet) I shut it off, went to get the camera to record some videos. Then I started it up, and recorded these videos:
First is idling at about 1400 RPM, for 30 seconds. Second is idling with a few blips of the throttle, also for 30 seconds. The videos are 2.7 megs each. Thanks! |
pfierb |
oldest member ![]() ![]() ![]() Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 ![]() |
On my 73 2.0 had a similar noise....turned out to be a 10mm washer that a local "expert" Porsche shop had accidentally dropped into the manifold while changing a base gasket on one of the Webers.....they called me and said that the car had thrown a rod and for 6 to 12 thousand dollars they would rebuild the motor....I called one of the good guys in the club EJM and had the car flat bedded to his shop where he pulled the motor and found the washer embeded in a piston and cylinder head....Ed was able to clean up the gouges and reassemble...at a later date he pulled the carbs off and put the FI back runs great now....jeez but that is a long story just to tell you that something could have fallen off or thru of one of your carbs.
Lo-Fi Version | Time is now: 20th June 2024 - 11:26 AM |
