> 911 oiltank, making it work...
Jeroen
post Dec 3 2005, 07:35 PM
Region Association: Europe
I'm gonna use a 911 oiltank in my six conversion (it's out of a 3.2 carrera)
Today, I cleaned up the tank and ground off the stock mounting tabs (which are on the "front" of the tank, thus useless)
(IMG:http://www.914world.com/bbs2/uploads/blog-1133643274.jpg)
Next, I fabbed 2 new mounting tabs
(IMG:http://www.914world.com/bbs2/uploads/blog-1133643284.jpg)
And welded them to the tank
(IMG:http://www.914world.com/bbs2/uploads/blog-1133643294.jpg)
Tank roughly in place against the firewall in the front trunk
(IMG:http://www.914world.com/bbs2/uploads/blog-1133643306.jpg)
(IMG:http://www.914world.com/bbs2/uploads/blog-1133643322.jpg)
Nice thing about the 911 oiltank is that it has a drainplug
I took out one of the "donuts" in the front truck floor and the drain will be positioned over it
I used some pvc plumbing pieces from the hardware store to cover the hole up and still keep it easily accessible
(IMG:http://www.914world.com/bbs2/uploads/blog-1133643342.jpg)
Another nice feature on the 911 tank is the sender for a oil level gauge
I still need to make a mounting tab near the bottom of the tank and the tabs on the chassis, but so far, it's working out nicely
brant
post Dec 4 2005, 07:06 PM
QUOTE (thesey914 @ Dec 4 2005, 10:46 AM)
early tank..
Positioning the tank on this side would complicate the oil return (to cooler). Line would have to run under front of motor and back to cooler. Hose from scavenge to tank would be a cinch though.
What if you modified the motor oil cooler to have the fitting point rearward instead of forward....
then put the tank-to-cooler scavange line behind the motor?
what are the physical measurements of the early tank.
I'd like to take a tape measure to the chassis now.
hmmmmm.....
brant
Jeroen   911 oiltank   Dec 3 2005, 07:35 PM
seanery   that's pretty slick Jeroen! <...   Dec 3 2005, 10:29 PM
Aaron Cox   why use a 911 one? just use a big ol peterson one....   Dec 3 2005, 10:59 PM
Jeroen   ...   Dec 3 2005, 11:24 PM
Aaron Cox   hmmmmmmmm good point on the hoses... but use a ra...   Dec 3 2005, 11:26 PM
sixnotfour     Dec 3 2005, 11:34 PM
Aaron Cox   ...   Dec 4 2005, 06:17 PM
Bleyseng     Dec 4 2005, 06:48 PM
brant   ...   Dec 4 2005, 07:06 PM
thesey914   Another possible consideration would be extra heat...   Dec 5 2005, 02:25 AM
- Lo-Fi Version Time is now: 1st May 2026 - 03:40 AM
