crank end play, how much |
toon1 |
Dec 4 2005, 10:00 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
How much front to back movement should I be getting on the crank? I seem to have quite alot approx. 1/16".
bottomend |
Dec 4 2005, 11:54 PM
Member Group: Members Posts: 180 Joined: 27-August 05 From: LA,Ca Member No.: 4,683 |
It should be .004 axial play. No more. No less.
Take two shims and put them into place on the end of the crankshaft, place FW on to crank, install bolts, then tighten the flywheel down to about half the TQ value. Maybe around 40 ft lbs.... Measure the axial movement using the little tool and your feeler guages and subtract .004. This number will be the size of the super important 3rd shim you'll need to install. rememeber... no more than .004 movement. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:23 AM |
