solex |
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States ![]() |
Ok so I finally decided to dig in an try to figure out the problem with my lights. Basically the low beams work but the high beams, although they work, will not stay on unless I hold the turn signal indicator back.
I remove the switch and completely cleaned the contacts, I removed the relay and also completely cleaned it. It appears that the metal plate on the top of the relay is not being held down to supply power to the lights. So I replace the relay with a new one but it has a lead "labeled 30" the orginal relay does not have this lead. What should I do with the 30 lead? Also I tried to clean all of the grounds, are there any grounds that are not obvious that need to be cleaned? Thanks, Dan |
ewdysar |
What happens here, stays here. ![]() ![]() ![]() Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 ![]() |
I had the same problem earlier this year. The original style relay is NLA and has been for a while. The new relay with the extra tab is the official replacement. A jumper needs to be added to make the new relay work but I forget where it connects. I got my answer on this board.
"the truth is out there" Eric edit: It's a thread titled "Headlight issue" from Jan 6 2005. I don't know how to do a link straight to the thread, I found it using the search... PS. the short answer is: Jump tab 30 to tab 56. |
Lo-Fi Version | Time is now: 1st August 2025 - 04:32 PM |
