Fresh Air Box Motor, Is it possible to rebuild? |
solex |
Dec 6 2005, 09:49 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I just removed my fresh air box and the brushes seem to have melted all other parts of the motor look fine. Is it possible to get new brushes and or rebuild the motor?
Thanks, Dan |
dmenche914 |
Dec 7 2005, 01:48 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Sure is possible for rebuild, Not sure of new brushes, but a motor repair shop is a good bet. I have cannabilized spares for parts. Be sure to lubricate both bearings (top and bottom) also.
Then the best thing to do is before you put it back, is add a bug screen between the intake and the cowl louvers. The stock screen (only on later cars, early had none) is much too course, and allows fan clogging insects,and pine needles to get in. So go get some aluminum window screen (don't use the nylon, it wont last long) clean it and paint it (I choose gloss black) then fit it between the box and the cowl. This will solve the clogged /flooded fan problem for good. be sure that the seal on top of the fan intake is good, and water tight to the body. test it after install (but before you put the gas tank back) with water, to make sure water from the outside does not rundown the outside of the air box from the cowl, else you will have wet feet and rust problems (sure the water does drain out the pan of the car, but it tends to soak in the gas tank felt pads, and rust the tank from the outside in, hence it is important to have a water tight trunk, also check the wipers while you are at it. They can be dissasembled and lubed, and resealed. Make sure no one in the past adjusted the wiper shaft "stickout" length too low. If the top of the shaft bushing is below the "water level' of the little dished wiper "wells" (design flaw!!) then the water will leak on down them. removing lube, and rusting the shafts. besure to paint any bare spots on the outside of the gas tank (where the pads sit) and if the pad nearest the brake resovoir is suspected of being brake fluid soaked, be sure to wash it well (and dry it) Replace the rubber gas tank hoses, use smooth hose clamps. besure the seam on either side of the cowl is water sealed (a new plastic strip is cheap, and I would clean up and paint any rust and add sealer under the strip. (located at bottom of windshield post) Thats my to do list for the front trunk when the gas tank is out. good luck. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:35 AM |
