Front struts |
Front struts |
spare time toys |
Dec 9 2005, 04:51 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
So if I want to get the 3.5 inch spacing what year struts do I need to be on the look out for? And what ones will work with the 1971 vintage front end that is in the car? Or does any one have a line on a set of spindles cheap and I will put them on the struts I have (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
Eric_Shea |
Dec 9 2005, 08:36 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I know the feeling. You should be able to sell them. I sold a set on eBay for around $50.00.
The problem is, when they went to a vented rotor they spaced out the front caliper by 7mm. They had to move the center of the rotor out by roughly 1/2 that distance. So... if you put a set side-by-side on the table you'd see the later hub has a higher (further out) rotor mounting surface. Good luck with it. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:15 AM |
