> Custom front sway bar???, Coleman racing
Andyrew
post Dec 10 2005, 10:25 PM
Spooling.... Please wait
I really wouldnt mind putting a bigger front sway bar on my car, but since im plowing from understeer around town, im not really worrying about it..
BUT I am not rather liking the 350 or 500 I'd have to spend to get a good bar on my car.
I currently have a stock bar up front, and 22mm T bars (ya, thats my kicker up front...)
I was thinking that one of these coleman bars would work..
(IMG:http://www.colemanracing.com/catalog/images/pn658.jpg)
They have the bar thickness from 3/4in to 1 1/2 in...
Bar is 37.5 in long...
Could it work?
I know there will be fabrication involved (im cool with that.. only means more fun..)
http://www.colemanracing.com/catalog/index...&sort=2a&page=1
Also, they have Just the bars at different lengths. But only at 1 1/4 thickness. Lengths from 32" to 43" and .125, .188, and .25 wall (whatever that means)
Bars by themselves for 110 bucks.
Any thoughts??
Brett W
post Dec 11 2005, 03:50 PM
You will only make your car worse if you got to a bigger front bar. You should drop back to a stock sized or slightly larger torsion bar. 22mm bars are too big for a street car. A 19mm sway bar and stock T-bars is very manageable on the street.
You could take some steel arms and cut the spines off the end. Then drill four holes in each corner and bolt some 1/8 inch plate on either side to mount the end link in shear.
Andrew I would figure out what you want for this car. If you want a really potent street/weekend track warrior then I would plan on using a bar that goes up to 1 1/8 but if you aren't looking at playing with all the suspension settings and are looking for a set it and forget it, I would stick to something proven. These type bars can go up to 2+inches in diameter.
Andyrew   Custom front sway bar???   Dec 10 2005, 10:25 PM
Aaron Cox   check out slugmika's blog. he has a custom swa...   Dec 10 2005, 10:33 PM
Dan (Almaden Valley)   Putting a bigger bar up front is not going to help...   Dec 10 2005, 10:39 PM
Mueller     Dec 10 2005, 10:41 PM
Andyrew   I saw his bar as well. I sent him a message, mayb...   Dec 10 2005, 10:43 PM
Andyrew   As per my problem of understeer, Yes, I know. But...   Dec 10 2005, 10:45 PM
Dan (Almaden Valley)   Stock bar is right at 40 inches in length.   Dec 10 2005, 10:48 PM
Andyrew   Thanks dan! That gives me one step closer.   Dec 10 2005, 10:50 PM
Aaron Cox   PM sent   Dec 10 2005, 10:51 PM
Andyrew   PM recieved... http://www.914...   Dec 10 2005, 11:04 PM
dlo914   <...   Dec 11 2005, 01:34 AM
Andyrew   Already dibbed out... lol Gona be traded for a f...   Dec 11 2005, 01:41 AM
dlo914   <...   Dec 11 2005, 01:44 AM
groot   I've used this type of bar for my car. I got t...   Dec 11 2005, 11:16 AM
jd74914   I wish they made the bars with square end mounts i...   Dec 11 2005, 11:40 AM
Brett W   This style of bar is really common on race cars. ...   Dec 11 2005, 11:51 AM
Andyrew   Groot, would you mind sending some pics if you hav...   Dec 11 2005, 12:20 PM
Brett W   my setup will use bars less than 20inches long so ...   Dec 11 2005, 12:32 PM
Andyrew   Nope, and im asking santa for a Miller (or a linco...   Dec 11 2005, 12:40 PM
groot   Here's a pic... pretty dirty and partially dia...   Dec 11 2005, 02:12 PM
Andyrew   What was the length of the sway bar you used? Wha...   Dec 11 2005, 03:11 PM
Brett W   something just occured to me. When I was running ...   Dec 11 2005, 04:14 PM
jd74914   <...   Dec 11 2005, 04:46 PM
Brett W   if you lower your car with the a-arms parallel to ...   Dec 11 2005, 05:28 PM
Mueller   <...   Dec 11 2005, 08:30 PM
jd74914   <...   Dec 11 2005, 08:36 PM
Aaron Cox   <...   Dec 11 2005, 09:11 PM
Andyrew   Car will be dedicated autox and track car. With a ...   Dec 12 2005, 01:31 AM
Brett W   You really should run more rear spring. Then you ...   Dec 12 2005, 08:24 AM
Andyrew   Cool stuff. I have Engman long kit in a box, and ...   Dec 12 2005, 08:54 AM
groot   I use a standard length 37.5" bar. It's 7/8" d...   Dec 12 2005, 01:08 PM
Andyrew   I definately need more front tire... My tires are...   Dec 12 2005, 03:10 PM
groot   Those pieces will make a nice adjustable stabilize...   Dec 12 2005, 03:55 PM
Brett W   Andrew, try this first. Stock front bar Camber, a...   Dec 12 2005, 04:06 PM
andys   I have to agree with Kevin and Brett. I think you ...   Dec 12 2005, 06:01 PM
Andyrew   I know my setup is way off. I gave myself a baseli...   Dec 12 2005, 06:19 PM
Andyrew   Heres a pic of the configuration at the wcc. I t...   Dec 12 2005, 06:20 PM
Brett W   Listen if the car is pushing in your current setup...   Dec 12 2005, 08:30 PM
groot   Dude, Have it your way, we're just trying to ...   Dec 13 2005, 08:44 AM
Andyrew
  Dec 13 2005, 09:25 AM
d914   not a techie guru, but the cars do turn better und...   Dec 13 2005, 09:44 AM
groot   <...   Dec 13 2005, 10:34 AM
Andyrew   Trailing arm braking, and engine braking generally...   Dec 13 2005, 12:33 PM
- Lo-Fi Version Time is now: 14th June 2024 - 10:30 AM
